ok so the engine has been running great going on 2 seasons now since i rebuilt carbs, water pump etc. and i go out ALOT! like 2-3 times a week! so had to replace water pump impeller again already..anywayyys
Ran great UNTIL last friday i was out it was running fine just as usual, then all of a sudden on the return of our trip at a little over 1/2 throttle it starts missing like crazy, so i increase throttle and get intermittent bursts of power, then it levels off but not near the speed it should be at with the percent of throttle given. but were like whatever just hoping it gets us home!
then upon entering the no wake zone coming off plane engine is vibrating/shaking very badly. then upon exiting zone i gunned it and it still had the shake and would barely get on plane at full throttle. UNTIL it got a few quick bursts of power again intermittent and then leveled off again...
i just replace plugs too like 2-3months ago when i had a similar problem, thought it was missin which turned out to be just a clogged fuel filter, cleaned it out and ran like a dream until now.
NOW this seemed to be the same thing to me, SO i looked at filter and it had bunch of junk in it, so i cleaned it out and went out again on sunday, ran great little over half way out to same destination as friday, then it started same story over again. im like ugggghhh
SOOO im wondering what my problem is..
I dont want to pull the carbs if i don't need too..
Im thinking that something SOMEHOW(who knows with the filter) got into one of the highspeed jets????
All comments and info is greatly appreciated
Thanks, David
Thanks, David
