This is my second season boating with a 2004 Yahama 90 carb. Last month, on several trips, the buzzer came on with the RPM reduction whenever I hit a particularly large wake. Yesterday, it came on and is continuously on, and I was able to limp home with the motor below 2000 rpm.
I think this has got to be a loose wire somewhere. I have plenty of oil, a steady stream of water out of motor, and the last time the motor went into permanent buzzer mode, it was with 2 minutes of running. I looked at the oil talk cap, and there are 4 wires coming out - pink, green, green/red and black. The black isn't connected to anything, it has a spade terminal that is just lying loose. Could this be the issue?
I don't have the yamaha gauges, so I can't tell anything more about what is going on. Any help is appreciated
