BOATERBOBSY90
- Sep 5, 2009
- 1
85 90 hp new oil pump # 6H1-WS132-00. Bought from boat (dot) Net I have changed out the oil pump with some grinding and the new hardware, But as other posts explain there is no instructions, I need to know the order of the dischare ports on the new pump, there are 2 ports to the side and 1 is on the opposite side pointing up. Which hose goes to what port is my question? 2 are pointing to the front of the motor, = I l , = means 2 ports to the front, I is the injector motor, l is the port to the top. Also is the firing order top to bottom or bottom to top? PLEASE HELP !!
Bob
Bob
