Hello!!
I have a 1996 Yamaha 250 carb. I decided to remove the lower unit and check the impeller, but it would not come off. I discovered the lower unit shaft seized in to the block.
This is what i did so far. I used a few screw drivers to try to open the gap between the lower unit and mid section. I got like 1/4 in, but i discovered that the shaft moved 1/4 in from the lower unit and not the block. Luckily i have a spare lower unit. I also tried to move the power head from the mid section and nothing.
Here are my options. I think?
I can turn the engine upside-down try to spray some chemical to dissolve the rust, than heat it with a torch.
Or cut a hole in the mid section. cut out the shaft. Pull out the power head, then try to remove the shaft with chemicals and heat.
The last think i want to do is damage the power head which works great. Has this happen to anyone before? what is the best chemical to dissolve the rust? will heat damage the power head? any tipsss???
Best Regards,
Jon
Best Regards,
Jon
