hello every one,
i have been going over the oil injection system as per the seloc manual. As testing states i ran engine on pre mix and tested the injection system, i noticed very little from the injection lines. I have done some research and found that what i have seems to be normal, i havent actualy measured it but to be safe im and changing the pump, i have cleaned the lines and tested the check valves..
Since i had removed the pump & lines , i did not label the lines and which cylinders they go to..... How do i find out what port on the pump goes to what cylinder? or does it matter? I do know i have the new pump design with th check valves in the lines...
Thank you for your time!,
Rich
Rich
