14livingston
- Aug 19, 2009
- 2
I have a 7.5 Suzuki (pull-start) that does not get spark. I replaced and re-soldered the wires since taking this photo. The large coil in the photo has two yellow wires that aren't connected to anything. Two wires are attached to each condenser (I'm pretty sure that's what they are). One goes straight to an ignition coil, then to a spark plug, the other is attached to that white plastic piece, listed in the Suzuki parts manual as a contact point (I don't know what that means). Should the coil in this photo be wired to something? Any other advice?
Thanks,
Derek
Thanks,
Derek
