Re: 1986 Yamaha 150 Steering Shaft Lube
Thanks, Triumphrick and Fortec Five. I bought the boat/motor about 15 years ago. Maybe the first owner had a Zerk fitting (grease nipple) added, but I doubt it. The fitting on my motor is on the right side of the motor pivot shaft tube, down about two-thirds of the way to the bottom. As I said, I would like to see a shop manual diagram of the pivot shaft assembly. Know where I could get one? I wonder if there is a bearing at the top of the shaft or only at the bottom. When I insert grease into the Zerk fitting, I see old grease exit at the bottom of the shaft but not at the top.
