Hi, I recently bought this vx-250 and it seemed to run fine on the back of the guys boat sitting on land. However once I installed it on my boat and put it under load, the motor would not climb past 3200 rpm and then would loose all power as if fuel was cut but does not die, it keeps surging up and down in RPMs.
Sometimes it idles smooth and sometimes rough, not consistent.
I have been reading many post on iboats but nothing has helped so far.
I have taken a remote tank and connected directly to the outboard with a primer ball and had a friend pump gas while I slowly added power and I was able to get the motor up to 4500rpm and stay there for a few minutes but as soon as I touch the throttle she died out again.
New filters, new plugs, mechanic inspected fuel pumps and indicated they were all good, ran SeaFoam threw it. I have drained the carb bowls and they all seemed clean.
I hate missing out on summer. Any help would be appreciated. Thanks
