Model p115 TLRS
History: went to start motor at ramp battery dead. Replaced with new.
returned to lake ran motor a hour every thing ok. trailered unit 4.5 hrs fished three lakes in three days. On third day Motor trimed up all the way in shallow water I noticed oil running out of power head cowling (2cyl). Did not start it.Used 9.9 to get to dock which I was at for a week of fishing. Removed cowling, saw cap poped up on oil tank. Ok this is where oil came from. At this point I know nothing of this system. So i noticed a knoch in cap which it was straight above where it was supposed to be. Pushed it back down, cleaned motor check remote tank oil. It was at or near bottm. Added oil.
Started motor got to deep water to lower it down for take off. Motor went to 2000 rpm and that was it. No aludilbe alarms or any thing wrong in dash. pulled cover ,cap poped up again.Push it back down started motor up it ran great. At this point I still no nothing of this system but I,m learning quick. At dock read owners books.It was some what help full. I over filled the main engine tank with toggle switch everything seems fine. next day it will not go above 2000 rpm or so. Pulled cowling again cap popped up again. So i pushed it back down. It ran fine all day. Next day it would not do above 2000 rpm.( cap was not pop up this time. Pulled boat came home pissed off. Got on Iboats forums and started training myself. Ok I ran the oil test that every body refers to here on this site cleaned tank etc. Even ohm out the main tank sensor all three swtich tested ok. At this point control module suspect. All alarms worked. I how ever have not checked power read on any leads. Which is next. I also would like help on the ohm specs for the trim switch which is in question due to rpm loss.
( Now you know what really happens) I know now I could of lost this engine by what I,ve read on this forum and in that trouble shooting topic I pulled off here.
Need pointed in another direction or the correct one.
