yamaha 225txrz. v-6 HPDI 2001
The exhuast plate gasket between the cylinders (Under the coils) was leaking so I went and changed the gasket. I cleaned out all the threads and cleaned all the bolts. I just wanted to know what the torque specs are for those bolts and if anything should go on the bolts as far as perfect seal or just grease? thanks in advance.
