92 yamaha 200 outboard,not a perfect motor ,but always get me back home,two problem,wont idle good,it will sneeze and cut off,if i bump the choke it will stay idle sometime,sometime even i bump the choke still cut off,adjust idle screw buttom out,still wont idle(wounder timming is off?)carb been clean few weeks back,what would u look first,and after 1000rpm it run fine till 4800rpm it will barge down,if i back off gas it will run finr again(maybe water in gas?)any help from here,thanks.
