I have a 1997 40hp Yamaha percision blend 2 stroke. The motor will get up and go then slowly lose speed after 2 minutes. Then,you back off the throttle, punch it down again...It will get up and go again then slow down again after 2 minutes. Compression is fine(100,100,100). I put this post up about a month ago, but didn't get any responses. Since then I have done the following: carb job, replaced gaskits on carbs, changed gas,run sea foam, changed plugs, checked fuel filter, new fuel line and prime bulb and new fuel line connections. The bottom carb did have a little trash in it. Myself and the kind people helping me are completely out of ideas. I would greatly appreciate any advice on this issue. Thanks!
