I set the throttle link like the manual said to and the pointer is pointing at 7 degrees ATDC in neutral low idle and 25 BTDC opened up but the actual timing is over 10 degrees ATDC at idle( maybe as much as 14 ATDC, no marks past 10) when checked with a timing light.
Does this make any since to anyone or have you seen this before?
I have not put it on the water yet to see how far it advances at WOT, if I adjust the linkage to get the 7 degrees at Idle I am afraid it will push the timing too far advanced at higher RPM, but it makes it run a lot better at idle.
Can anyone give me any advice on what it may do if it advances past the 25 degrees called for and or any information on how to solve this problem?
