I have searched several things. But can't find much help. I have a 89 Dt75. I have put in new plugs. Have rebuilt the carbs and the fuel pump. All the cylinders have about 115 to 120 psi. New fuel filter, fuel lines, and clean fuel. No leaks anywhere.
Can any one tell me what the psi coming out of the cyl to the fuel pump should be? I have less than a pound.
The motor is run like new out of the water. Will start right up anytime, and idle good in water. will run across the water for a few seconds with the chokes 3/4 closed, then just falls on its face, and dies. At this point it is hard to start, it it will even start back up, like its starving of fuel.
I thought maby an electric fuel pump may help but don't know the fuel lbs.
I would like to have this thing running right by this Saturday. It realy sucks to get past the no wake and lay into it, only to be disappointed. Thank god for trolling motors.
Please anyone.
Please anyone.
