striderboat
- May 27, 2009
- 7
Just put boat in water after winter. Ran well for about ten minutes then purposely slowed down to 8-10 mph for 15 minutes (no wake zone). When tried to accelerate engine would run good up until about 3500 rpm's after that the engine would not accelerate and would slow down when increasing throttle. Runs fine at low rpms. Tried the next night same problem rpms increased to about 4200, if the throttle is increased the engine would slow down tojust under 4000 rpms and the rpms would go up and down about 400 rpms.
115 Yamaha 4-stroke 2002 (330 hours)
Prior to winter mechanic winterized boat, replaced thermostat, fuel filter, etc and used valve-tec decarbon. showed codes for eng to cold and shift switch.
Had to recharge batteries prior to putting in water. They may not be fully charged.
Mechanic said I should run the boat to see if it cleans itself out, any thoughts?
