I have a 2002 Yamaha 50 hp 4-stroke which I took out of winter storage recently. Recently alternates between running fine, and then missing. I have checked the fuel filter which is clear and the fuel is coming out of the fuel pump okay.
I have sparks on all cylinders. However, if I disconnect cylinder 2 or 4 when the engine is missing there is no change in the engine idle (when missing). (Interestingly, cylinders 2 and 4 run have seperate coils).
However, if I disconnect cyliner 1 or 3 the engine dies (as expected). I have alternated spark plugs for what it is worth with the same problem.
With the fact that there is no change in the rough idle with disconnecting cylinders 2 or 4 it makes me think these are the problem but I am unable to narrow down the problem further.
Does anyone have any suggestions? Thanks!
James.
James.
