This is my first post so hello to every one.
I have twin 03 Suzuki 140s on my 26 Catamaran. I was getting ready to tow my boat to Mexico for a big trip and decided it would be a good idea to change the water impellers. I have done this before so I was familiar with the repairs. I unbolted the lower unit to drop it. As I dropped it, it went down about 5 inches and it wouldn't drop any more due to the drive shaft being stuck in the upper unit. rite away I noticed a lot of rubber chunks that didn't look very good. It took me about an hour of trying different things until I used two hydraulics to press it all the way out allowing the drive shaft to completely drop from the upper unit(channel). I soon found out the reason it wasn't coming out smoothly is because of the salt water built up that accumulated on the wall of the upper unit unit/channel. I found out that all that rubber deb re is chunks from the drive shaft bushing that normally would sit at the base of the drive shaft housing(the first place the drive shaft goes through as you are putting the lower unit back into the upper unit). Also The area where the bushing would normally sit in the housing was all worn out to the point where it actually made a whole through the housing.
I took the lower unit off of the other motor to see how it looked and it also was extremely hard to drop, and the bushing on this side was still in place but also shot about 50%.
Looks like I am going to have to replace the Drive shaft housing on one of the motors and I might be able to save the better side.
I have no idea how or why this damage was created as this bushing from what I was told and per repair manual is not a part that need to be replaced under so many hours.
I use the boat on a weekly basis and I have around 600 hours on it now. I always flush out my motors on every trip.
Does anyone know what the heck could have happen to cause this issue and how to prevent it in the future. When flushing out the motors does the fresh water also go through and around the drive shaft to flush it out?
At first I was afraid that I might have some more damage inside as without that bushing in place water was getting up in the drive shaft area, but from what I gathered is that that bushing does not provide a water tight seal anyway and water does flow through that area.
Also, do you think that this issue might have caused the drive shaft to warp/bend?
I couldn't find any number to a tech at Suzuki to ask about this situation.
What do you experts think about this issue.
By the way, unfortunately parts are not available till next month, so there goes my plans that I have been planning for the past year.
Attached is a pic of the drive shaft housing (#1) and the bushing (#5)
Thank you
Thank you
