yodude00169
- May 10, 2009
- 1
I have a problem with my 1987 150hp Suzuki motor. The trim works intermittently on my 189V stratos. Attempted to use the secondary trim switch at bow to confirm switch operation. When trim working, then both switches work, otherwise nothing works.
Also, my trim position sensor does not work, but I don't see this being related directly.
**Could a relay somewhere be bad, and where would I trace it.
Additionally- The middle cylinder that I believe brings the motor entirely out of the water has a leak. *Would this affect the trim. If so, then why is performance not always affected.
Found that the butt plug was worn out this past weekend. 1st weekend I ever had this boat in water more than few hours. Water actually filled the battery compartments and started comming up from the bilge. Now I have a new plug. My buddy suggested that I should have had all my Live Wells Plugged too.
**Would plugging the live wells prevent me from taking on additional water in those wells, or should the live well drainage level work.
Thanks
Adam.
Thanks
Adam.
