I have a 1989 Suzuki DT 25. Ran fine 2 years ago when last used--went to start it and I can't get any gas to the carbs---
1) I checked the hose and tank connections--I can get pressure and gas to the engine
2) checked the fuel filter and I get gas pushed through the filter lines
3) checked the fuel pump and it pumps when the engine is cranked and I get gas to the carb
NOW I can't get the gas into the float bowl of the carb--Just won't pass through the plastic line mount into the carb?? ANY IDEAS on what might be up. Motor runs fine on gas sprayed into the carbs--Just starves out because no fuel is reaching the carb??? I need Ideas on where to go from here? Thanks JIM
