Hi all, new to the forum and need some advice. I have recently acquired a Suzuki DT65 (1985) and it wasn't pumping water to good so we thought we change the impeller. The impeller looked fine but we replaced it anyhow. Now we are having real problems with getting the gear case and the part where the pump housing is to all line up. I cant seem to be able to move the gear linkage up or down, and there is a 5mm gap around the front of the plate where the pump housing is. It feels as if something isnt slotting into place which would make it all close up. Am i right in thinking that the prop should turn freely if the gear is in neutral? I'm wondering if anyone else has had this problem, and what the solution to it is!?
Regards
Steve
Regards
Steve
