ARCHSEA BUNKER
- Mar 6, 2009
- 50
Rodbolt, Still Cannot Get Oil From Remote, If Brown Wire Is Damaged Within The Ecu How Would That Affect My Diagostics, I Am Sure I Have The Right Harness But After The Connection From The Remote Oil Tank ' 4 Wires' Down Low On The Starboard Side The Brown Wire Continues On To An Other Conector Which Goes To A Manuel Tilt Switch Under The Cowling, The Ecu Has Signs Of Melting, The Motor Runs Fine, I Am At My Wits End, Its All The Origenal Harness And Never Gave A Problem In 8-9 Years Thank You
