I have a DT65 that will start good, idle fine but when you put it in gear and start to throttle up it bogs and dies. Oil reset and level ok. Prop turns freely, not wound with fish line. Lower unit is ok, no binding. Rebuilt the fuel pump and it is ok. The motor has set for more than a year with out running. I have run Sea Foam in the fresh gas while idling,but no improvement. Any suggestions.
