DukesFin
- Oct 12, 2005
- 500
When I start the motor on the muffs, everything is fine. If I (in neutral of course), give it gas/throttle, then release, the RPMs do not go all the way back down.
The magneto control lever(s) stop by about 1/4 of an inch from the "end point". I can push them back by hand, lowering the RPMs back to normal idle speed.
Can anyone tell me why this is happening?
I've adjusted the throttle cable at the lever as much as possible already...
Thanks in advance!
Thanks in advance!
