I have a 1996 60hp yamaha 2 stroke which has a problem with the trim & tilt.
When pressing the switch to lowering or raising the engine you can hear an audible click but nothing happens. After letting the engine rest, the tilt will go up but not down. If left long enough - over night the it will then go down. However if you lift and lower the engine a few times it starts all over with only the audible click being heard.
Is this the trim & *** motor or something more sever?
