Well I rebulit my water pump today. Now its not working. This is what I did.
I drop the lower unit. Remove the plastic housing , remove SS cover remove the old impeller and all the old gasket. Now putting it back togather with new one. First I make sure everything is clean.I put the new gasket on than the SS gasket then another gasket. then the Key or woodruff, side the new impeller in .Put the SS cover over it . Then the plastic housing screw everything down. Put the lower unit back on the motor (Yamaha 90HP).
Turn the motor over on nurtral engine running on ear muff. But no water come out the pee hole. Should I try to put the engine in gear see if water come out. Any help will be great.
Thanks
Thanks
