Hi there, I recently bought a boat with a DT115 that needed reconditioning which has been done. However,I find the motor is hard to start.ie; I sometimes have to crank it over for a minute or so. I squeeze the fuel bulb until hard and then some more just in case, raise throttle lever 1.5inches, press choke and turn key. I'm not a mechanic obviously but have a basic understanding of the workings of a motor and it seems to me it has a carburetion broblem. Was out recently and had to change over fuel tanks after the motor died, squeezed the bulb hard and cranked over without choke. No go. Squeezed bulb again, more cranking and after about 3mins it started. Very nerve racking, rough seas and don't want to repeat that experience. HELP! Could it possibly be float levels, carb air/fuel mixtures, jets etc or all of the above! Is this something a novice with basic knowledge can look at? Any suggestions please?
