chico andrade
- Nov 9, 2008
- 4
Hi,
I have a 96 suzuki dt55, some time ago it was really difficult to start the engine, and used to take many trys for it to start. Now it totaly refuses to start. I tested and found no spark in any plug. I got the seloc repair manual, and in this manual there are some resistance test to the various coils. I proceed the tests and found that, acording to the resistance, the three pulser are good, the battery charge coil is good and the gear counter coil is also good, however the condenser charge coil had infinite resistance, that way being at fault. I am no expert, but the manual says that this coil sends current to charge a capacitor within the cdi unit, that in turns sent the current to ignition coils. So, being broken this condenser charge can actually prevent all cylinder to have spark, right ?
I was told that I need a DVA to test the output of the coil, ok, but is the resistance test worth to trust, or is it a total waste of time ?
Any further help? What else should I test ?
thanks for any help,
chico
chico
