All right guys, I know this has been posted before (I did a search) but the steering froze up on me on my Yamaha 70hp 2 stroke and have a few questions. The rod inside the steering tube is frozen in there. I unbolted the cable from the starboard side and the cable/helm turns freely and the motor pivots just fine when unbolting the tiller rod. I moved the rod almost completely into the tube after whacking it with a hammer and hitting it with some WD40. Hopefully I didn't mushroom the end. I will definitely have to get the engine hoist out and unbolt the motor to go any further. My questions are:
Any other methods or penetrating oils I should consider? Will using a torch (very carefully) help at all to loosen this sucker? Seemed to have a lot of dried up grease and rust in there, not sure if heat will cause it to seize worse.
Also I'm concerned about the end of the Teleflex cable. I put a wrench on it to try to turn it (perpendicular to rod) and also put a rod through the end (where the tiller rod gets bolted) and tried whacking it out the other way towards port. How tough is that end, just wondering how it's attached to the rest of the telescoping rod cable.
Any input is greatly appreciated.
