I recently bought an Avon RIB with a bad Suzuki motor for $100.
The Suzuki is a 2 stroke 30 HP 1992 model.
There is a hole in the #2 piston. The cylinder wall doesn't seem too bad but there is some very light grooves. The other two pistons seem ok. The motor turns over freely and was told it runs but rough.
Can I just hone out the middle cylinder and install a new piston (assuming everything else is good) and be good to go? Will it be reliable?
Thanks
Thanks
