Hi, I have a 1990 DT 65 which pees water from tell tale and exhaust port when on muffs / under pressure, but does not come out of tell tale when in the water under normal running conditions, t but he water still comes out of the normal exhaust port though. Is this the impellar??
I have looked at changing the impellar and have a PDF manual but it is a little unclear. What is the procedure for removing the lower leg? do I need to drain the gearbox oil to do this.
Any help much appreciated.
Regards
Graeme
Regards
Graeme
