Dear all,
I hope someone may be able to help.
I have just trailed my boat from the UK to the South of France - 1200 miles!
The boat has been flawless since I purchased it (Zodiac Yachtline 530 & DF140 Suzuki).
We have just tried to launch her and the power trim will only go down - it will not go up. It is NOT the case that it is struggling to go up, rather nothing what so ever happend when the UP button is pressed. The trim motor works as normal when lowering the engine. I have tried both the control button and the one mounted on the engine.
I see that on the trim unit there is a screw labelled 'open / close' - Is this an emergency release valve which will at least enable me to manually raise the engine??
Any ideas what the fault could be??
Many thanks for any help you can offer.
Thanks Mark
Thanks Mark
