Hoping someone can shed some light.
I have a pair of 2003 Johnson/Suzuki 115hp 4-stroke motors. These are great engines except one of them is acting up a bit. One starts very hard when I let it sit for a week or so. Once I get it going it seems to only run on two cylinders and then will eventually run on all four once I nail it and leave it nailed for a couple minutes...I know with the water in the gas people have been saying this has caused fuel injectors to get clogged up, however the other motor runs perfect using the same gas. One day while anchored I emptied the fuel filter and put chevron techron into the tank. The motor ran good as new for the rest of the day. When back to the boat after one month, now the engine is acting up again. Even after I have it running on all four cylinders it still seems a bit off. At idle it appears to have a very slight misfire/skip, while the other engine runs perfectly. Any ideas? Should I just get the fuel system cleaned?
-any input would be appreciated.
