I am looking for a neutral switch for a Suzuki 1983 DT50. It mounts to the side case and is a plunger type; contact is made when the lug on the shift linkage depresses it.
I checked Browns Point Marina they don?t list the part in their inventory. I plan on calling them after the holiday to see if it has been replaced by a newer/different part number.
I am inquiring to see if anyone else has had to retrofit a different switch into a similar application.
Any and all recommendations as to where I might start will be greatly appreciated.
Thank you.
Thank you.
