Hi,
1993 Yamaha T9.9 EXHR 4 stroke. Erratic water stream coming from pee hole. Have cleared several obstructions from pee hole. Still poor stream. Will service impeller. In addition, the upper cylinder water bypass outlet (water outlet nipple on top of head at port side) is blocked. Could not clear with 180 psi air stream into nipple. Under the valve cover in the upper left hand corner is a stainless screw which seems to be in line with the upper bypass outlet. Does anyone know if this is a cleanout for the water path? Looks like it has thread sealant on it. Not shown in Yamaha or Clymer manuals. If not, are the water flow channels accessible by removing the exhaust cover on the port side of the power head? And/or, do I need to pull the head off to clean up this mess. Tried removing the thermostat cover and a vinegar flush, but no dice.
Today, things got worse. No flow after motor warm up, then steam from both pee hole and exhaust. Hope impeller is not toast. Flow returned after cool down. Now flow continues from pee hole for ~5 secs after shutdown, but not an impressive stream.
Thanks for any advice. Apologies for lengthy post.
Bob
Bob
