Anyone know what the correct tachometer pole setting is for a 2003 Yamaha 70hp 2-stroke motor? I was told 6pole position but think i might be getting false tach readings.
What kind of tach is it and model? If those numbers are for poles, then it should be set to 6. If there is a P after the number they are talking about pulses which in your case would be 3P.
