woodnknots
- Oct 20, 2006
- 96
When I say wierd, I mean that it sounds sort of like a Harley Davidson motorcycle idling. Not very smooth at all.
I took it out on the water for the first time ever today to test it out (just bought it, installed it) and it seemed to run a little rough at low speed, then when I brought it up on power it came to life with all sorts of power, then right away started losing power, then surging, then losing power, then surging. I couldn't get full power back at all, so I immediately turned around and came back.
What I've done so far- Checked spark gap-good .040
Checked all plugs to make sure all had soot from firing (they do)
drained carb bowls (maybe a water problem?).
One more thing, the sticker on the inside of the motor calls for NGK BR8HS-10 but it has brand new B8HS-10 (no R). Does this matter?
Motor is Yamaha model 200TXRS serial 766580
