rustyfisher05
- Jul 20, 2008
- 2
So, I thought I bought a new motor and would be able to get at least a couple of outings without issue. The motor is a '08 Yamaha 4 stroke 9.9 tiller outboard. I picked up the motor last week from the dealership, where it ran great (once). I had the shop load the motor in the back of the (covered) truck, where is sat until I went to try it out this weekend. Upon getting to the boat ramp, and removing the motor from the truck, I noticed a small amount of oil outside the motor. I went ahead and attached the motor to the boat, and trimmed it up to launch the boat. After getting the boat in the water, I notice oil traveling rather readily out of the intake on the motor.
I inspected the spark plugs (light with gas), and I tried to turn the motor over (via electric start). Given a newly charged battery, the starter clicked, but no turn of the flywheel. Even manually, I tried to move the flywheel, but with no avail? I not sure where to start. Anyone with ideas?
I'm aware of needing to correctly set down a 4 stroke motor horizontally. Given the shop loaded the motor, I assumed they were loading it correctly.
