I have a 1984 Suzuki DT 74. It has sat for ~3 mounths with the engine trimmed up and turned all the way to one side. Yesterday I lowered the engine and it would not turn at all. I tried to grease all the nipples on the engine and that did not help.
Then I loosened the nut on the steering cable. As pulled the cable out the steering wheel would turn.
I could not move the inner steering cable without the outer moving. Does this mean the cable is stuck inside?
Also I could not push (move) the engine with the cable dettached, is the problem? I am trying to isolate where the problem is.
My knowledge of boats is limited. Let me know if you need any other details.
Thanks,
Mike
Thanks,
Mike
