krisnowicki
- Jul 11, 2007
- 1,172
I was out yesterday first time with less then 5 people in the boat so i wanted to see how fast the boat would run. GPS in hand i run it up to 5400 rpms with a 21 pitch prop. After about 4 or 5 mins the over heat alarm comes on and immediately shut off. Let it cool of and started it back up and ran for hours at 4500 or less with no over heat on the way back in i run at 5200 and it overheats again. It seems only over 5000 will it over heat. The boat has a new impeller on it and i flush constantly. The manual says it may be the tstats but they did ok in the boil test in the manual. What else am I missing? The boat pees strong enough to cut a hole in concrete.
