Good day,
I recently picked up a Suzuki 25 HP Oil Injection 2 Stroke engine - I think its around a 93. With that said, it suffers the following symptoms:
- Idles as long as I want, but if I put it in gear and keep the throttle low, it stalls after seemingly coughing
- Checked over the fuel line from tank the motor, all is good. Primer bulb is good.
- See a bit of gas floating away from the back of the boat
- Pulled the cover, checked the spark plugs with the following results:
- Look new as in probably replaced end of last season
- Top two have blackish soot on them, thus indicating they are firing
- Bottom one is crystal clean - looks like it has never fired, though it did have some gas on it.
- Motor seems underpowered, but I'm not used to these motors
I suspect that the big red flag is the bottom spark plug, but what are my next steps in dealing with this issue?
Cheers!
Kris
Cheers!
Kris
