hey everyone,
got an issue i was hoping you could help with.
today i was underway about 5 to 6 mph (1700 rpms) and the oil light starting blinking. i killed the motor and and checked the oil- all was normal.
fired it back up and tach did the normal starting sequence. ( all lights on, guage went up to 800 rpm? ((one notch below 1000)) then back down to 0)
i started it, tell tale was looking good & drove 1/2 mile to mooring at 5mph.
at mooring i let it cool and checked oil level- all good. turned the key on and the oil light flashed again, but this time following by 1 beep, then 2 beeps. It stayed flashing and continued to beep twice, pause, beep twice etc.
any idea what this code means?
thanks in advance!
dualie
thanks in advance!
dualie
