orlandoscout
- Jun 27, 2008
- 2
First I must disclaim that I know very little about outboard repairs.
Recently I took my Scout out and as I turned the boat I noticed it was difficult to steer, I forced the steering as I made a sharp turn and the steering wheel broke off. I assume that the problem lies in the steering cable, therefore I have purchased a new teleflex steering cable, and helm. I attempted to disconnect the cable/rod off the motor however came across some problems. I loosened the bolts at each end of the cable/rod and attempted to pull the cable/rod out of the housing. (see photos at http://www.kodakgallery.com/I.jsp?c=p2z82qh.7wzrgg4d&x=0&y=nmjlpi&localeid=en_US ). I was able to pull the cable on the left side of the motor(looking at the motor from inside the boat) however nothing happened to the rod on the right. I hoped that the rod was 1 piece that extended from the left of the motor to the right, it appears as though they are not connected. I then took a hammer and hit the rod on the right side from left to right. The rod moved approx. 2 inches however nothing happend on the left side of the motor. I am not sure if the rod should be driven through the housing completely. If so please provide recco for how to drive it all the way through to the other side.
