Help, RODBOLT or anyone
My 2001 150 HPDI Yamaha model Z150TXRZ, starts and idles ok, when I bring it up to around 2000 it starts surging violently as if running out of fuel. Here's what I have done so far. I have checked the VST tank and electric motor, all spotless, I put a Gauge on the test port and it shows a constant 50 psi at all times. I removed the filter/strainer between the VST and the mech pump and installed a short piece of clear plastic to observe if any air is flowing. It shows only solid fuel at all times. Using the Yam diag SW, it shows fuel pressure of 750 psi and 5 MPa (I don't know what the MPa is?) when running ok. As it starts breaking up the fuel pressure drops to about 13 psi and the other drops to 1 MPa. Am I facing replacement of the dreaded $1000 mech pump. Is there any thing else I should check. I was told it should run with the belt off up to about 2000 rpm?? If the pump, is there any way to clean or try to gt it working?
