Have a Suzuki DT50 2 cyl 2 stroke. Have an issue with the motor that idles OK, goes into gear OK, few seconds after applying any throttle motor dies.
Took this to a dealer and he said it is a compression seal on the crank between the 2 chambers/cylinders?
Would this be true - sounds more like carbs.
Thanks Pete
Thanks Pete
