Blowing Fuses on '85 Yamaha 115 HP
Lately my '85 Yamaha 115 has been blowing the 20 amp fuse in the engine when I shut the engine off and then re-start. It seems to blow it when I turn the ignition key to the on position. Does anyone have a solution to the problem? Thanks a bunch!:)
JUSTINTIME
Re: Blowing Fuses on '85 Yamaha 115 HP
you have a short to ground somewhere
clean all connections
