jason_rst
- May 26, 2008
- 17
i have a 1985 or there abouts yamaha 75hp 2 stroke outboard, what is the correct fuel mix??? im using 50/1 at the moment but i dont know if this is correct also it has trouble picking up the revs under load! if i rev it in neutral from idle it takes a while to pick up but at high revs it seems ok could this be fuel mix or plugs?????????
