Long story. Bought rebuilt lower unit this winter (old one was cracked and had water in oil). Ended up rebuilding the entire water pump before installing lower unit. Problem is: strong stream from telltale at idle and up to 5000 rpm with engine in neutral. But, underway, at 4000 rpm or higher (boat is a 19' Whaler) going about 27 mph, the telltale stream gets weak and eventually the engine overheats. Never had this problem with my old lower unit. Seems like the water pump is starved for water on the intake side at higher rpm/boat speeds resulting in lower pressure/flow. Thoughts? Suggestions?
