Tempo to Racor gas filter replacement
sar3195
I now have a Tempo water separator/fuel filter on my boat. The filter that is on the mounting bracket is a Tempo MF10. That filter replaces a Mercury 35604941 or 35807172 filter. Can I replace the filter with a Racor B32013 without replacing the filter screw in bracket that the fuel lines connect to?
sar3195
Re: Tempo to Racor gas filter replacement
I called Racor and they said that the B32013 will work just fine.
