I recently purchased a 07 cape craft 15 flats with a 50hp yamaha. center console. Have had the boat less then 3 weeks. First day on the water the shift box grenaded, causing the engine to stick at about 4000rpms in neutral. Took back and had replaced by the dealer. Told it was a defective peice. Everything was fine. Sounds good, now I am a very avid fisherman and raised around boats. Knowing that it needs break in and reading the book to make sure I did not forget anything. I took a few days off and went fishing not pushing it over 2500rpms and finally getting about 2.5-3hrs on it decide to take it up and see how she handled on plane for a moment. Well needless to say she never got on plane and sat at 3000rpms and then overheated. Took back to the dealer and was told that it looked like to the dealer that I sucked up some sand the water impeller took a dump. Now I have done a little research on the engine and find out that it was manf. on 01/06.
If it did suck up some sand, could have this happened that fast and easily? Also from reading some of the forums is it possible that the impeller dry rotted from sitting for so long, waiting for a sucker for me to come along and do it in?
Anyfeed back or help would be appreciated.
Thank you
Scott
Thank you
Scott
