mudcatwilly
- Aug 11, 2006
- 32
I have a 1990 Suzuki DT85. I fired it up in the driveway last evening to fog the carbs and it started up as it usually does and the tilt/trim was working fine. This morning, I launched at the boat ramp and here's what happened:
Lowered trim into water
Turned key, engine cranked a couple of times, but did not fire all the way (normal for my engine)
Turned key again...nothing. No cranking, no clicks..dead silence. Trim/tilt was dead too. (Battery was fully charged and I switched batteries and got the same result).
Pulled boat out of the water to check wire connections. Everything was connected at the engine and battery.
Jiggled wires just before the controls and all of sudden, I got tilt/trim and I got the motor to crank.
Figured I was good, put it back in the water, tried it again. Again, dead silence when turning the key and tilt/trim was not working. I checked connections again, jiggled wires again...nothing.
I know the battery is good. I don't understand how it was fine yesterday and today, there seems to be no electricity getting to the motor or tilt trim. I would appreciate some thoughts on this.
